azrving
Jul 11, 2018Explorer
It sounds like you have the fuel delivery in order so it's probably not lean. I'd be sure the governor is set correctly. The gov is a balancing act between the flyweights and the gov spring. Any slop in the linkage or incorrect adjustment can cause that problem. Some linkages will have a very fine spring covering them. The spring connects to the arms that the linkage is in to take up the slop.
But being borderline lean could be an issue. What does the plug look like? Black, brown, white?
