wa8yxm
Jul 12, 2018Explorer III
Continous surging (Hunting it is called) indicates an improper fuel/air ratio. I believe that is too rich. Stuck choke, or mal-adjusted carb are the most likely causes.
IT should be fairly Hz will wiggle a bit when a BIG load (A/C. Water heater. Microvave) kicks in/out but overall should be very stable.. "Purr like a kitten" is the applicable phrase if it's running right. A fairly big kitten.
Having RV issues? Connect with others who have been in your shoes.24,403 PostsLatest Activity: Aug 02, 2026
