azbrewer
May 04, 2015Explorer
When I removed my panels to swap to new MH I had to use an 18" crescent to twist off the brackets held down with silicone sealant. Used lag screws through and sealant under each bracket. I could not pry them off, they just started to bend. The tilt brackets I use now only have 3M UHB double stick tape holding them on, been there for over 7 years without any problems.
