brulaz
May 06, 2015Explorer
Rather than the tape or epoxy, with something like Filon, I would try 3M 5200 Marine Adhesive caulk with long (or lots of) brackets giving you lots of surface area to adhere to. Could drill holes in the brackets so the 5200 wells up into the holes. And would need weight to hold the brackets down while it dried.
Don't think screws would be necessary as that 3M 5200 is basically permanent. Pretty sure the Filon would rip out before the joint.
