filrupmark's avatar
filrupmark
How to add 2nd. A/C
I have a 30 amp fifth wheel. I would like to add a 2nd A/C in the bedroom. A RV dealer told me they could add a 20 amp drop leg. That would be the 2nd ac wired directly to a seperate receptacle mounted on the side of the trailer. I would have to plug in my 30 amp cord like normal and then if I wanted to run my 2nd ac I would have to plug in a extension cord to the seperate receptacle and then plug the cord into the 20amp outlet next to the 30 amp on the park power . Has anyone ever heard of this. That would mean that the parks power would have to be wired for 50 amps total.??????????????????
  • In many cases there are 100 amps available at the pedestal. 50-30 and 20 amp outlets that can be utilized at the same time. It depends on how the pedestal is wired.
    A drop leg is quite commonly used for just that application.
  • What he is proposing would be your simplest solution. Parks with a 30 amp plug invariably also have a separate 20 amp plug. Unless they wired the 20 from the 30 (not likely) you would have no problem.
    Others here have reported doing similar modifications for running second ACs, heaters, etc.
Having RV issues? Connect with others who have been in your shoes.24,320 PostsLatest Activity: Sep 20, 2025
