crcr's avatar
crcr
How to adjust Electric RV Awning?
We have a 2011 Jayco TT we bought in January. We are about to take an 800 mile trip and I noticed an issue with the awning. When it is closed, the rear arm closes tightly against the TT, but the front arm won't quite close. FYI, the motor is in the front head, so I presume the rear head is spring-loaded.
I found a video on youtube and the man said that in these cases, usually either the fabric has slipped to one side or the other in the slot, which you fix be sliding it to line it up again. It appears to me that the fabric on ours is lined up.
Or, he says the fabric has stretched, in which case, he says there is nothing you can do except replace the fabric. He said to measure corner to corner diagonally and if one measurement is longer, then fabric is stretched. I did measure corner to corner, and in fact, one measurement is 1 3/8" more than the other. This is pretty close to the gap at the front arm when the awning is fully retracted.
Below I am posting pictures of the awning fully retracted, so you can see the gap at the front arm compared to the rear arm. The awning fabric is about 19'. Does anyone have any suggestion of any way to adjust out this slack at the front arm other than buying new fabric for the awning?
Also, do you think it is safe to take one more trip with it like this before addressing the issue? What would be the expected cost to have a 19' awning fabric replaced?
Left Arm, closes tight to TT
Front Arm, notice gap at top when closed.
Having RV issues? Connect with others who have been in your shoes.24,353 PostsLatest Activity: Jan 21, 2026
