dougrainer
Jul 14, 2014Nomad
Gjac wrote:
I understand that this blockage is a slow build up over time and understand how to check to see if the refer is totally blocked. What I was trying to figure out is if temperature measurement could alert us if the cooling unit is starting to have blockage. I would think the blocked areas would be cooler than the rest of the tubing. I check my radiator this way to look for blockage and it shows cold where radiator starts to develop blockage.
Yes, you can use a temp measurement, but it has been so long, I do not have the variables or temp normal measurements. It is just as easy to do the 120 element hot wire test. IMO, all cooling units will have a small blockage over the years due to the occasional running off level. NOBODY, always runs the refer within spec all the time. Doug
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Aug 30, 2026
