dougrainer
Jul 14, 2014Nomad
The temp measurement will be at the burner flue as that is the area that heats up(overheats) when you have a partial or blocked cooling unit. The normal temp of a Norcold 1200(dual 120 elements at 450 watts total is around 350 degrees. SO, a Dometic 2 door or Norcold 2 door uses a 325 watt element, so I will guess that temp in the 325 degree range. The Norcold recall box is set to trip at over 700 degrees. So, you have a variable of over 350 degrees before the recall trips. Doug
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Aug 30, 2026
