TLLOYD's avatar
TLLOYD
How to check inverter
I have a Xantrex Pro XM1800 inverter on my 2016 RV. After the just over a year of FINALLY getting all of the issues fixed during the first year and a half with the help of Thor I have since ran into an issue with the inverter.
I have two 6 volt batteries both showing above 6.5 volts. I have checked the volts to the inverter and it is above 13 volts.
When I turn the inverter on it just flashes on the panel. Sometimes 13.5, sometimes OL and the inverter itself located in the rear outside cabinet "clicks" like a heartbeat. I guess like it wants to come on but doesn't. The lights in the RV dim in and out also and the refrigerator does the same. I have noticed the inverter itself gets hot to the touch.
I turn everything off (lights and refrigerator) and it still does the same thing.
I can check the load in as the power cables from the batteries are exposed where they hook up to the inverter. I read to check the load out, but can't figure out how to do this.
I basically have to run the generator when traveling to keep the refrigerator cold until I hook up to shore power.
  • Voltage alone does not indicate battery health. How old are they? Can you disconnect all loads and see what happens?
Having RV issues? Connect with others who have been in your shoes.24,211 PostsLatest Activity: Mar 08, 2025
