DrewE
Oct 03, 2017Explorer III
x2 on what BFL13 says. I also would suggest replacing the converter; besides cleaner power and happier batteries, a new multistage converter will charge your batteries a whole lot faster when they are discharged than the existing one (assuming it has separate charge and converter outputs).
You could also wire up a DPDT switch in the TV power cord and flip between the wall wart power and the battery power as needed with the switch. A center-off switch is recommended to ensure that it has break before make contacts.
