MM49
Nov 19, 2013Explorer
Don't clean them. If you use solvent they will only get dirtier. Just get a bearing packer and pump new grease into them until clean grease flows. You will never get the contaminated grease out of a bearing without heated solvent. Then it is a multiple step process to remove the grit. Just pump in new grease.
MM49
MM49
Having RV issues? Connect with others who have been in your shoes.24,393 PostsLatest Activity: Jun 12, 2026
