westend
Nov 19, 2013Explorer
WILDEBILL wrote:What are you not understanding?westend wrote:K6DKO wrote:About 10 seconds if you plan to get your hands on them.
Do I need to soak the bearings in kerosene to get them clean? If so how long?
??? What are you talking about???
Bill
I've never seen or heard of anyone merely soaking a bearing in any solvent until they're clean. If the term "soaking" is the same as a parts washing machine, then, yes, there will be some time duration involved. I would assume since the OP is asking how to clean bearings he doesn't own a machine.
If he does decide to clean them and if he uses kerosene, the best method is to use a parts brush and roll the bearings by hand to remove grease. I would usually follow up with a rag.
As someone else posted, I don't clean them anymore except to remove any excess old grease for inspection. I use a bearing packer and push in new grease until the old is pressed out. MO is that these hub bearings are not close enough in tolerance and have sufficient hardness that heroic cleaning methods aren't necessary. Should say that I don't operate my running stock in terribly harsh environments. If I was rock climbing or did a lot of desert travel, I might clean up everything as I don't like dirt in moving parts.
BTW, axle grease is one of the nicest skin softeners made. :B
Having RV issues? Connect with others who have been in your shoes.24,393 PostsLatest Activity: Jun 12, 2026
