down_home
Nov 20, 2013Explorer II
Hnold the bearing in your hand after cleaning away all the grease you can and use the fingers to work fresh greas in one side and the old out the other side.
A bearing packer or whatever it is called holds the bearing between two cones and you connect a grease gun to the fitting on spindle. It forces grease in one side and old grease out the other.
If you have grit or metal in the bearing or if it feels loose throw it away and get another.
Having RV issues? Connect with others who have been in your shoes.24,393 PostsLatest Activity: Jun 12, 2026
