wa8yxm
May 25, 2014Explorer III
Since I have two refrigeration devices I wait till the day before payday (So the larder is close to bare) and move all into the other cooler and the transport cooler (Insulated picnic type cooler) for temp storage.. Turn off fridge.
I will use a small (150 watt) heater to help warm it.. They do NOT recommend using a hair dryer or other heat element but the 150 watt is not bad.
I also help loosen the ice a bit... That too is not recommended, but done carefully it works.
Transfer Ice to Sink, Sop up water in Freezer with towel, Clean all with baking soda solution, Re-assemble, Turn on,, Re-stock.
Having RV issues? Connect with others who have been in your shoes.24,394 PostsLatest Activity: Jun 15, 2026
