enblethen
Aug 28, 2015Nomad
Get the same or slightly larger then your current one.
If your rig has a 30 amp, you may need to jump to the smallest PD amperage. (45 amp I think).
Verify size of conductor between the converter and DC distribution panel. Conductor must be able to carry full output load of current. 45 amp should be #6.
Remember size is not only charge rate but the load of your 12 volt DC loads.
Having RV issues? Connect with others who have been in your shoes.24,369 PostsLatest Activity: Mar 12, 2026
