myredracer
Aug 31, 2015Explorer II
WFCO is model 8955PEC. I would prefer to just replace the converter "guts"). It looks like the PD 9200 series along with the Charge Wizard. Can these be reset for AGMs or do you have to order the correct one?
The wire size from our battery to converter is #8. Even if not upgrading the converter, considering also the length from battery to the converter? The mini-circuit breaker in the A-frame is 30 amps. I would assume that I should also increase the breaker size?
I'm also looking at installing a Viair on-board compressor which would have a draw of around 15-20 amps depending on which model. Would this have an affect on sizing the converter? Duty cycle could be anywhere from 15% to 100% as I have no idea yet which compressor to use (just for topping up tires and winterizing).
Having RV issues? Connect with others who have been in your shoes.24,374 PostsLatest Activity: Apr 05, 2026
