wa8yxm
Sep 01, 2015Explorer III
myredracer wrote:
WFCO is model 8955PEC. I would prefer to just replace the converter "guts"). It looks like the PD 9200 series along with the Charge Wizard. Can these be reset for AGMs or do you have to order the correct one?
9200 has the wizard built in but there is another model that is designed to "Drop in" where the guts of the WFCO are now.
Since your WFCO is a 55 amp, I'd go with the xx60 from Progressive Dynamics I believe the 4600 line is designed as the "Replacement/Upgrade" model. Basicaly it is a 9200 but without the outer case so it's a bit less expensive.
Randy can advise you for sure.
The dongle (is optional on both lines.. This is the device that gives you control over the unit.
NO: They do not make a re-program kit for AGMs but even Lifeline says the Wizard does a good job of maintainint their AGMs so I'd not worry about that.
Having RV issues? Connect with others who have been in your shoes.24,374 PostsLatest Activity: Apr 05, 2026
