LGBolon's avatar
LGBolon
How to Disconnected Fridge Beeper
We have a Norcold 2 door fridge. The FL code keeps flashing but the fridge is working on both 120 V and and LP. Nevertheless, the beeping is CONSTANT.
How do you disconnect the beeper to stop the sound until we can get a tech to look at the fridge?
Thanks.
  • Have you tried shutting the refrigerator completely off and then turning it back on again to see if it stops beeping? You may need to unplug from shore power, flip your on-board battery kill switch to off to truly shut off the refrigerator. But it might stop the beeping when you power everything back up.
    Well, it's just a suggestion and doesn't cost anything or require anything be dismantled (yet).
  • Norcold makes lots of 2 door fridges............WHICH ONE DO YOU HAVE??
