efiguero
Sep 01, 2013Explorer
Sfla2 wrote:efiguero wrote:
I found it, it is in my house battery compartment, but no idea where the tool to lower it is?? Any ideas?
reread my post u use jack crank handle it its like mine.
tell the guy to locate Sp T then follow the cable to the side,
it would help if u listed all info abt rig brand, model ect
My apologies, it's a 1997 Fleetwood Tioga Class C,(the specific model # escapes me and I'm already in bed so I'll check in the morning) 30ft, on Ford E350 Superduty chassis. As I mentioned I found the crank, but not sure where to find the jack or the jack handle. I assumed it would be close to the crank but I did not see it and have not encountered either a jack or a jack handle in any of the storage compartments in my short time owning this used rig. The only handle I've found is the pole to pull out the awning, so if this pole does double duty as a jack handle then I'm in business. If not I still need to find the jack handle. Thanks again for all the help.
Having RV issues? Connect with others who have been in your shoes.24,363 PostsLatest Activity: Mar 03, 2026
