DougE
Sep 26, 2013Explorer
If you have two round holes on each side of the radio (used to be typical with Fords) you can make a removal tool out of coat hanger. Bend in a "U". Grasp lightly about a 1/4" from the end with a wire cutter and make a groove around the wire (both ends). You need one of these for each side. Slide into the holes and then pull out gently.
Having RV issues? Connect with others who have been in your shoes.24,397 PostsLatest Activity: Jun 25, 2026
