1995brave
Sep 26, 2013Nomad
Step 1: Park your vehicle and ensure that the parking brake is set.
Step 2: Open the hood of your vehicle by pulling the hood release next to the driver door on the floor.
Step 3: Disconnect the negative battery terminal to ensure that your equipment will be safe during this process.
Step 4: Using a Philips head screwdriver, remove the 1 screw in the ashtray cavity located below the radio.
Step 5: Carefully pry out the silver trim panel using a flat head screwdriver.
(Optional Step: You can put a small piece of duct tape over the head of the screwdriver to avoid scratching the trim panel. But if you are careful when prying, you shouldn't need to do this.)
Step 6: Unplug everything connected to the trim panel allowing you to fully remove it.
Step 7: Once you have the trim panel and moved out of the way, remove the 4 screws surrounding the radio.
Step 8: Gently pull the radio out and unplug the 2 connectors on the back.
Congratulations you have removed the radio out of your 2003 Jeep Liberty.
Having RV issues? Connect with others who have been in your shoes.24,397 PostsLatest Activity: Jun 25, 2026
