Golden_HVAC
Jul 27, 2016Explorer
Are you using solid #4 wire? File it down with a grinder.
If it is stranded, then cut off a couple of strands, until it fits. Unless you are actually running more than 40 amps through the wire, it is possible to cut it down to #8 size with no voltage loss.
Good luck,
Fred.
Good luck,
Fred.
Having RV issues? Connect with others who have been in your shoes.24,373 PostsLatest Activity: Mar 31, 2026
