Almot
Apr 12, 2016Explorer III
myredracer wrote:
A TV is going to be connected with an HDMI cable so not sure why we have 2 sat connections outside? There is a co-ax connection at the rear of the trailer which is for cable TV input with a sat. co-ax next to it which would suggest it's for input??
You have 2 coax connectors outside in case if you need both cable and sat dish at the same time. Or 2 different sat dishes. I don't think it matters which one you plug you dish into, though you might want to play and see if there is a difference.
TV will be connected with HDMI cable ... to what? Normally, HDMI cable goes from TV to sat receiver, and receiver is plugged into the coax receptacle inside the trailer with a short coax extension cable. From that wall receptacle there is another coax cable hidden in the wall, it goes to those 2 receptacles outside and to the OTA on the roof.
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Sep 03, 2026
