myredracer
Apr 16, 2016Explorer II
liborko wrote:
If you can't figure out how the satellite cabling is done I would call trailer manufacturer or run new cable altogether. Setting everything up for HD only with one receiver only would make everything simpler. You can use your receiver to help you set everything up by going into menu-system setup-installation-point dish(menu-6-1-1). Good luck.
Think I have pretty much figured it out and is simpler than expected. Looks like I've found a nice used dish for cheap and then all we'll need is a tripod, some cable, signal finder and a compass.
Looks like I can use dishpointer.com to get the required azimuth, skew and elevation depending on where we happen to be camping.
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Sep 03, 2026
