myredracer's avatar
myredracer
Explorer II
Apr 12, 2016
How to implement a satellite system?
We've been around to enough CGs now to find that OTA (or cable) reception and channel availability can often be dismal to non-existent. Nothing's worse than not being able to watch Survivor, DWTS or other fav. show... :M (We are "camping" and roughing it, lol.)
This past weekend we ran into a fellow camper that said if you have sat TV at home, you can just bring along one of your PVRs from home and buy a dish. Our sat TV provider buys their service from Bell so I think all we need is a Bell dish? What else would we need or need to know about?
Our TT is factory wired for satellite TV. Has a co-ax outlet at each of 2 TVs inside and 2 locations outside and don't know how it's all connected. Dealer did not know and the manufacturer has no info. Does each TV location require a PVR and is one of the exterior co-ax connections one of the inputs? A TV is going to be connected with an HDMI cable so not sure why we have 2 sat connections outside? There is a co-ax connection at the rear of the trailer which is for cable TV input with a sat. co-ax next to it which would suggest it's for input??
Do we just need a dish & tripod, some RG6, a separator, compass and a signal finder and we are good to go? Here is one package that is available Canada Satellite. Can we just buy a Bell dish on CL?
Are there different types of a dish that we need to be aware of and are some better than others? The only downside to having sat TV would be where to store the dish and tripod. Can go in the truck I suppose. Maybe a roof mount is something to consider?
  • donn0128 wrote:
    Do you have SD or HD receivers? Do you want HD or is SD OK for camping?
    Yes, you can buy a portable dish and tripod off the internet. You can also buy a automatic portable dome that could work.
    We're looking for HD providing it's not a lot of additional cost. Our receivers are HD.
    The new ultra HD would sure be nice!
    RoyB, it seems to me that the satellite doesn't "care" where you are and you just need to be pointed at it so I can't foresee any real issues but I don't know a lot about this stuff. We're currently signed up for 2 or 3 bundles and get around 2,000 stations/channels across NA but only around 5-10 percent or so are HD. Way too many duplications too and there's only maybe 20 or so HD channels we actually use. They are supposed to be changing the regulations (this year??) so that you don't have to buy their bundles and choose just the channels you want. I'm hoping to finally be able to get some programs I have been missing like documentaries, travel shows, etc. (HD of course).
    Doesn't the dish have to be specific to your service provider?
  • RoyB's avatar
    RoyB
    Explorer II
    We did just that all the time with DIRECTV when we had their service. I would bring along two SAT RCVRs from the house and had a portable DIRECTV Dish setup that had a head with two outputs on it.
    This is back when Standard TV was what every one was watching...
    The simplist way way to bring along al couple of RG cable and run one to each of the SAT RCVR ANT inputs you brought along... Should fire right up for you once you get it pointed correctly. I would connect the VIDIO OUTPUTS of the SAT RCVR to the VID INPUTs on the two trailer TV sets. This way I could use SAT TV-OTA TV-CABLE TV with using the TV remotes.. click click click...
    You will lose your house location LOCAL TV if you have that signed up for. This goes away as soon as you leave your zip code area.
    My SAT RCVRs were older and most of the time when I unplugged on for any length of time they would lose their settings and I would have to call DIRECTV or login to them on the internet to get it reset. I taped the ACCOUNT INFO that you are going to need on each SAT RCVR... This was all OK with DIRECTV back then. They don't have anyway of knowing where you actually are anyway... I ran my two RG cables into the trailer through the storage bay door. They had rubber around the door edge so I could close the door and not bother the RG cables...
    I'm sure it still this way today...
    If you are wanting to get the fancy HIGH DEF TV SIGNALs you may have another problem - don't know about any of that...
    I stopped using my home SAT TV stuff when the Natl Broadcast Network changed over to Digital HDTV in 2009. Watching full mode High Def TV using the BATWING crank up OTA Antenna works great with the digtal HDTV coming from the local towns. This of course was a much better signal mode that came down from DIRECTV standard TV signals and is local TV from where you at showing the 24/7 WX RADAR stations etc...
    Of course you won't be getting some of those favorite CABLE TV programs like CNN USA TNT etc...
    Some folks report on here when they tried to get DIRECTV or DISH to install the SAT TV in their RV's they ran into problems...
    Bringing your own equipment with you is not the same issue... Try it all out at home and find out what you need to do there to make it work from the trailer.
    Roy Ken...
  • Do you have SD or HD receivers? Do you want HD or is SD OK for camping?
Having RV issues? Connect with others who have been in your shoes.24,344 PostsLatest Activity: Dec 26, 2025
