lc0338
Dec 27, 2015Explorer
Mount the winch so that it can swivel toward the load. side loads will always bunch the cable on one side. Is there a way to park a rig or something solid that you can run a chain from your anchor point and another vantage point? That way you can hook your winch into the chain between the two anchor points which will give you a straight shot to winch from. Even if you park your truck and put a chain around one of the wheels down low to the ground.
Having RV issues? Connect with others who have been in your shoes.24,383 PostsLatest Activity: Apr 25, 2026
