Artum_Snowbird
Dec 27, 2015Explorer
How about mounting the winch onto a plate with the right size ball on it, then pull out the cable to the anchor point. It would be quite easy to swing the winch from side to side to get it to spool properly. Most likely, the spooling would just occur naturally as the plate would swing a bit on the ball.
Set it up so the incoming winch wire is directly in line with the ball and just run an electrical cord out to the winch. After you pull it up, lift your trailer hitch and release the winch.
Having RV issues? Connect with others who have been in your shoes.24,383 PostsLatest Activity: Apr 24, 2026
