time2roll
Apr 29, 2017Nomad
My old Ford had a harness near the driver's feet to be connected to an aftermarket controller. Check if yours has similar.
Check your 7 pin connector actually functions. You will not have a brake signal but you can check the rest is connected and operating.
- Toolman52660Feb 19, 2024Explorer
If you have someone pushing on the brakes while you check it shouldn’t brake work then?
- Grit_dogFeb 20, 2024Trailblazer
That’s not how that works.
And you’re replying to a question that was answered in 2017.
Having RV issues? Connect with others who have been in your shoes.24,408 PostsLatest Activity: Aug 19, 2026
