time2roll
Apr 29, 2017Nomad
My old Ford had a harness near the driver's feet to be connected to an aftermarket controller. Check if yours has similar.
Check your 7 pin connector actually functions. You will not have a brake signal but you can check the rest is connected and operating.
Toolman52660
Feb 19, 2024Explorer
If you have someone pushing on the brakes while you check it shouldn’t brake work then?
- Grit_dogFeb 20, 2024Trailblazer
That’s not how that works.
And you’re replying to a question that was answered in 2017.
Having RV issues? Connect with others who have been in your shoes.24,408 PostsLatest Activity: Aug 19, 2026
