- FisherguyExplorerIf the truck has the 'trailer tow package' it will have the factory 7 pin connector and the original owner shoulda got the cable that plugs in down by the wiring block under the dash. You can probly buy that cord from a dealer or a used one from a wrecker.
- ScottGNomad
bikendan wrote:
If the OP's truck has an aftermarket receiver, it may not have the factory tow package, therefore no brake controller pre-wiring.
Take the VIN to the local Dodge dealer and they can tell you if it has the factory tow package, which would include wiring for the BC.
Not necessary. If the OP's truck has an existing OEM 7 pin connector in the bumper, then he has the wiring for the brake controller.
Dodge/RAM will not install a 7 pin without it being fully wired.
But this is really simple!! Stick your head under the dash and look for the light blue connector. It's the ONLY connector that color. - BinfordtexasExplorerThank you everyone. Yes what I was worried about was that the bumper is aftermarket so I was worried the plugs are as well. I used a multimeter and everything is working on the 7 pin. I googled through some installation videos and I found the connection to plug into under the dash. I'm assuming if it has the connection for the wiring harness that it's functional and just needs the harness and the controller.
- bikendanExplorerIf the OP's truck has an aftermarket receiver, it may not have the factory tow package, therefore no brake controller pre-wiring.
Take the VIN to the local Dodge dealer and they can tell you if it has the factory tow package, which would include wiring for the BC. - The_real_wild1ExplorerLike ScottG said your truck is wired already. Under the dash.
- ScottGNomadIf you have a stock 7 pin connector at the back of your truck then yes, you have the wiring for a trailer brakes.
It is light blue, about 1/2" wide X 2" long and is usually tied up under the dash on the left side. Binfordtexas wrote:
Put a test light or meter on your 7-pin connector or take it in to a trailer shop.
I realize I need a brake controller but I'm trying to figure out if the truck is already wired back to the bumper. I don't know how to figure that out.- BFL13Explorer II
At the 7-pin and 4-pin on the bumper, use a multimeter with the prongs between "ground" pin and the various pins to see if you have any voltages (With the engine running) See a standard diagram for which pin does what. The brake pin (blue wire) won't be live, but the others could be for brake and signal lights etc.
Your 12v power line (pin 4) should go from 12.x with the truck not running (unless your truck has an isolator--Chevs don't, Fords do-) to 14ish with the engine on.
Check the truck's driver's manual for fuse locations that are for trailer towing, to make sure they are there and the right sizes. - BinfordtexasExplorerI realize I need a brake controller but I'm trying to figure out if the truck is already wired back to the bumper. I don't know how to figure that out.
Having RV issues? Connect with others who have been in your shoes.24,312 PostsLatest Activity: Sep 06, 2025
