wolfe10
Oct 08, 2017Explorer
First, the fan has BUSHINGS, not bearings.
And in many cases, they can be lubed in place. You need light-viscosity oil such as sewing machine oil in a dispenser with LONG tip.
Place a few drops on the shaft right next to the motor. Repeat a couple of times-- the oil will "wick in".
Note: This IS true for the Atwood furnace, suspect also applies to other brands.
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 26, 2026
