Lynnmor
Oct 09, 2017Explorer II
While not exactly the same thing, I have a wood fired furnace for my home. The two blowers are to be oiled twice a year, but they are buried inside the ductwork behind the furnace. I attached small diameter vinyl tubing to each end of both blowers and routed the tubing up and out. A small pill bottle covers the open ends and it is now a simple matter to squirt oil in each tube. If one needs to disassemble the RV furnace, it might be possible to add tubing.
To clean the residue from motor bearings, bushings, shafts or whatever, try naphtha (lighter fluid).
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 26, 2026
