maillemaker
Mar 25, 2018Explorer
I got the furnace out this weekend. I have the blower assembly disconnected from the rest of the furnace, but I cannot remove the cage fans from the motor shafts. I was able to break loose the set screw on the smaller fan, but not on the larger fan. And even when the set screw was loosened, the fan would not come off the shaft. Is it pressed on?
Steve
Steve
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 26, 2026
