reed_cundiff
Nov 22, 2014Explorer
We have six x 235 W panels (1.4 kW) with about 9+ kW-hr of LFP. I wrote that we could conceivably emplace another 3 x 235 W panels for 2.1 kW. We have not found a reason to do this but we could run the AC on 2.1 kW of panels without utilizing the battery bank.
40 Ah is only 600 W-hr. You could conceivably get 40 amps at 12 V from a 700 W panel.
Our max power was 1.3 kW this summer. The most we get this time of year is 0.93 kW. The panels are ganged in two series of 3 x 30 V (235 W) panels. The voltage is thus 90 V to controller from the two gangs in parallel. So 1300 W was only 14 amps.
Our grandson changed out the charging pin so that we had a direct link to the backup video without hooking/unhooking another cable. 120 W at 12 V from the pickup's alternator is ts to the 500 to 1300 W from the solar.
Reed and Elaine
Reed and Elaine
