path1's avatar
path1
How to measure how much solar we need?
(hope this is right section) Brought home TT last month and now have basics taken care of and RV is road ready. Now starting to think about bigger long term projects.
One project is, we would like to get some solar. Which I know nothing about. I suspect the first step is figuring out a starting place for this project. So I'm assuming that finding how much we actually need might be a good starting spot.
Is there any meter or way to measure to figure out what we need? I'm thinking, if we know how much we use, we could determine how big or small of solar project would be. Thinking in my mind about some type of elec meter that we see how much we use in a week.
Or maybe better yet; how did you figure out how much solar you needed?
Anybody care to pass on any good links or info on RV solar?
Thanks
  • How much you need and how much you can use are two different things.
    There is a spread sheet that you can fill out as long as you know what each device uses and for how long.
    You can base it on how much battery you have.
    You can use the rig and see what the daily drop in voltage on the battery is.
    Then again you may look at your roof after figuring it all out and see you need X amount of solar but only have room for half that.
    Honestly with the prices of solar being so low, I would cover the roof in panel and put as much battery as you can down below, go forth and be solarful. You can't expand the systems so if you run out of power, learn to conserve.
    I had a pretty good idea of how much power we needed but I also knew we were very conservative too. We took one panel with us as a portable to see if it would be enough or if solar would work at all. Within a day we went from being conservative to looking for ways to use the excess power. We now have more panel and went from 30-40 ah to 200 ah a day with all the comforts of home including air conditioning and we don't take a generator.
  • get something like this Power Amp/Watt meter
    put it inline with the battery measure how much power you use
    per day AKA 24hrs and per night
    to be truly effective for long camping periods
    the solar has to twice what you use between sundown and sunrise
    it has to replace what you used at night..while recharging the batteries and powering what power you use during the day
    however.. IF you merely want to keep from killing the batteries aka extend your stay and then recharge them while the TT is in storage
    you can use a smaller solar system
    yes figuring out Both how much you use and what you want from the solar system.
    most people do NOT need "the full blown ..double power"
    matching your nightly use.. is enough for most people
