Pauljdav
Jun 15, 2013Explorer
eric1514 wrote:
You might not need a 30 amps. 20 is enough unless you need to run the A/C and the microwave at the same time. You can wire a 20 amp circuit using a 30 amp RV outlet if you don't want to use an adaptor.
Eric
X2. This is how I did mine. I have 20 amp going to a 30 amp plug. I can run the AC no problem with no voltage drop.
The circuit breaker is the 20 amp so all is safe. If I overload it it would shut off. So far I have not over loaded it.
Paul
Having RV issues? Connect with others who have been in your shoes.24,384 PostsLatest Activity: May 01, 2026
