kaydeejay
Jun 15, 2013Explorer
DougE wrote:The key here is the SINGLE 30A breaker. If you hire a pro and he installs a DOUBLE breaker, then he has probably wired 220V as the TT-30 receptacle looks VERY similar to a 220V dryer receptacle.
30 amp single pole breaker. 10 gauge 2 conductor w/ground nomex wire. 30 amp receptacle w/box and cover. Black wire to breaker. White wire to neutral buss bar. Bare copper wire to ground buss.
Check it, then check it again - much less hassle than replacing all the electronics (and other stuff) in your trailer.
Having RV issues? Connect with others who have been in your shoes.24,384 PostsLatest Activity: May 01, 2026
