opnspaces
Feb 08, 2025Navigator III
I have one of those. It's definitely just a pull straight out to get it off. Just hook your fingers in the top by the on/off switch and pull. It's held on on the four side corners just above and below the air vents on the sides.
- Community AlumniFeb 08, 2025Not applicable
Thank you for replying. Mine was really stuck firm but I was able to gradually pry it open using a sharp strong knife earlier, screwdriver wouldnt even go in. May be the plastic had shrunk over the years never having been removed. Im trying to see if I can add remote controlled switch to it so that I can start the heater without getting out of bed after cold nights.
