GaryS1953's avatar
May 12, 2017
How to remove circuit board?
I have a Dometic RM2652 Fridge and I think this is the lower control board and cover. I'm not all that mechanical and I can't figure out how to get it off to take it in and have it tested. I removed the upper screw, but can't seem to remove the cover to get to the screws that are apparently underneath it. Is there a trick to it? Thanks
  • YC 1 wrote:
    Be sure to unplug the power cord because there is 110 inside the box and you can get across it easily when the cover pops off.
    My camper is strictly 12 volts now days, but really good to know and I appreciate the advice, thanks! I did unplug the 120 plug.
  • Be sure to unplug the power cord because there is 110 inside the box and you can get across it easily when the cover pops off.
  • Thanks guys. Maybe it will help if I wait till tomorrow and try it in daylight : )
  • ktmrfs's avatar
    ktmrfs
    Explorer III
    use a flat bladed screwdriver on the two lower snaps. lever towards the outside and it will release the clip. The one on the left is the toughest to get to.
  • When I did my Dometic I think there were 2 little plastic tabs / catches on the sides I had to release to get the cover off
