Bob_Vaughn
Apr 06, 2015Explorer
How to remove decor self leveling sealant from roof
How do I remove Dicor self leveling sealant from roof without damaging the rubber roof. I replaced the crank up antenna with a Jack antenna so there was some sealant from that antenna the the Jack antenna replaced that and it got knocked off by a wayward limb. Then the replacement antenna got knocked off by a branch so there is 3 layers of sealant. Once I get the Dicor off the rubber what is a safe way to remove the residue plus around the crank hole the rubber is coming loose from the roof what should I use to re glue the rubber?
