MEXICOWANDERER
Jul 14, 2016Explorer
Instead of a spring pushing up a bakelite plate with a pair (?) of brass contact pins showing, some manufacturers use a solid rubber plug for tension.
Is there a number on the base of the light bulb?
Is this lamp dimmable? A make-or-break question if LED replacement bulbs are considered.
Are there 2 contacts on the underneath base of the bulb?
Usually twin contact bulbs with the metal socket pins straight across from each other are a type of old-fashioned interior dome light bulb.
I strongly recommend nOT going to a chain Auto Parts store for advice: They start by asking make and model, number of cylinders and what engine size. Go to your local independent auto parts store to save your sanity.
Having RV issues? Connect with others who have been in your shoes.24,369 PostsLatest Activity: Mar 12, 2026
