j-d
Sep 15, 2015Explorer II
Back the screw out a little, say 1/8". Push the screw and the anchor should loosen. Then back the screw out 1/8" again and force needle nose pliers under the shoulder of the anchor. Then pinch against the head. This should extend the anchor toward its original shape. Extend the screw and pinch again. Repeat till you can get enough access to the shank of the anchor to cut it off or pull it out. Remove the screw and do so.
Having RV issues? Connect with others who have been in your shoes.24,386 PostsLatest Activity: Nov 08, 2021
