Farmerjon
Feb 17, 2017Explorer
Have you tried turning the bolt to break it loose? I know it's not threaded in.
i don't see signs of your pounding on it.
I would cut it off flush with the square tubing and use a punch to drive it out preferably from the threaded end if you can turn the tube, if not you may have to cut on both sides to make exit room.
good luck
good luck
Having RV issues? Connect with others who have been in your shoes.24,404 PostsLatest Activity: Aug 07, 2026
