LarryJM
Feb 17, 2017Explorer II
agesilaus wrote:westend wrote:
Heat always works when rust or binding is at hand. For a fastener of that size, a propane torch will ease the binding.
Yeah that was my first thought. Heat it up. I've found a combo of PBlaster first followed by a propane torch frequently works. The PBlaster will catch on fire so keep that in mind.
I'm a believer in PB Blaster, but for best results on really tough items you need to soak it multiple times and keep it soaking wet for like a day or even two to let the PB Blaster work thru the MUCK.
I'd go that route and instead of heating or hammering on it I would try a real powerful IMPACT wrench/gun on it. Multiple quick hits close together can bust loose a lot of things much better than force or single impact hits.
Larry
Having RV issues? Connect with others who have been in your shoes.24,390 PostsLatest Activity: Jun 05, 2026
