kaydeejay
Aug 17, 2014Explorer
outnabout wrote:The plastic is called Coroplast or Correx. It does not glue well, but Gorilla tape may work for you.
I need to repair a tank under the trailer. It is covered with a corrugated plastic material that is one large piece covering the bottom of the entire trailer. I need to cut it but don't know how to repair the cut.Any ideas?
If you want to replace it, 8'x4' sheets should be available from a sign printer near you.
I get it from Laird Plastics in Detroit. About $12/sheet of 4mm. All kinds of colors.
Having RV issues? Connect with others who have been in your shoes.24,380 PostsLatest Activity: Apr 16, 2026
