dougrainer
May 22, 2022Nomad
wpatters1229 wrote:
I have a 2006 class C four winds motorhome and want to start using AGM batteries. The charger inverter is the original one and I want to upgrade it to be able to charge the AGM batteries. Preferable a smart charger. Can I replace the current inverter charger in the same space or do I have to re-do that whole section that is currently under the side of the bed in the back of the rig?
You need to elaborate more. Very few Class C motorhomes had a INverter/CHarger 16 years ago. Especially if located under the bed(Heat Build up). More likely, you have a CONVERTER only. If you have a Converter, I would replace the Converter with a Converter that has an optional smart Charge module or setting for AGM batteries. You need to state Brand and Model of existing charger. ANY Inverter/Charger needs to be within 10 feet of the Coach batteries. Doug
