dougrainer
May 23, 2022Nomad
CONVERTER---Takes 120 input and outputs 12 volts to run the 12 volt loads on the RV. Secondary function is to trickle charge and maintain the Coach battery once fully charged when plugged into 120 Shore Power
INVERTER/CHARGER----- Connected directly to the Coach batteries and has a hi amp BATTERY CHARGER. NOT CONNECTED DIRECTLY TO THE RV 12 VOLT SYSTEM. It is connected to the Coach batteries and then the 12 volt connections are connected from the coach batteries to the fuse panel of the RV 12 volt systems. ALSO,(Inverter) certain 120 appliances(usually Microwave and TV/Entertaiment systems), when NOT plugged into Shore or Genset will take the Battery 12 volts and INVERT that current to 120 ac. Not very useful if you only have 1 coach battery, but will work.
INVERTER---- Which you state you have also. This appliance just plain Inverts 12 volt to 120 ac current and usually has less than 500 watts of power. Usually has a cigarette lighter quick plug if they are small Inverters. Doug
