opnspaces
Aug 17, 2023Navigator III
You probably have a 30 amp coach (3 blades on the shore power plug) If 30 amp it is normal to not be able to run two high draw items (Microwave, AC, water heater) at the same time. If you do it will most likely trip the breaker.
To run multiple high draw items you need a 50 amp coach (4 blade shore power plug)
