wgriswold
May 07, 2016Explorer
smkettner wrote:
Do the drain pipes just hang out the bottom?
Mine have a valve on the outside.
Consider a T and elbow in the picture and a ball valve below that is hopefully easy to reach.
Yes the drains just hang out the bottom. I considered a valve but was concerned about adding that weight to the pipe and it swaying about with no reinforcement. If I can find a light weight plastic sharkbite like valve I would use it in place of the end caps.
The straight flair it valves referenced above might work.
Having RV issues? Connect with others who have been in your shoes.24,389 PostsLatest Activity: May 26, 2026
