wgriswold
May 19, 2016Explorer
ImaginaryNumber wrote:wgriswold wrote:
I plan to just open the defective valves and add a Flair-it valve outside the trailer on the drain tubes. Will that work for you?
Good idea, but a little late for me since I cut out the PEX connector and butchered the supply line in the process.
Also, the blue drain is not PEX. It's some kind of larger poly.
Bummer!
Having RV issues? Connect with others who have been in your shoes.24,389 PostsLatest Activity: May 26, 2026
